Can't show 4 transtions buttons
Lynn Gariepy
August 7, 2014
We are on Jira v6.2.5. I have only 3 of 4 configured transitions buttons showing on the issue in the flow. Is there a maximum number supported? When we were on v6.08 prior to the upgrade, extra transitions were in a drop-down menu.
Jose M.
September 4, 2014
This can be changed, in order to have more transition buttons. Should be described in the admin guide. Just in case you would like to change the default value.
Nic Brough -Adaptavist-
September 4, 2014
Do you mean the previous answers were close to what you need, but you want more?
Or you want to close the questions because you have an answer? (Which you've already done because you have marked at least one answer as correct)
Lynn Gariepy
September 4, 2014
close
Lynn Gariepy
September 4, 2014
close
Jaime S
August 26, 2014
They should still be in the 'Workflow' dropdown menu. You can't see this menu?
This can be customized: https://confluence.atlassian.com/display/JIRA/Advanced+workflow+configuration#Advancedworkflowconfiguration-customisingtransitionsonviewissue
Kind regards
