Can't update UPM
Hassard January 10, 2013
I have followed: https://confluence.atlassian.com/display/UPM/Updating+the+Universal+Plugin+Manager#UpdatingtheUniversalPluginManager-UpdatingUPMbyfilereplacement
but can't find the necessary file/directory... here is a listing from our install:
1. Shut down JIRA.
2. Remove the existing UPM JAR file from this directory in your JIRA home directory:
plugins/installed-plugins
root@libertine jira # pwd
/opt/atlassian/jira
root@libertine jira # ls
atlassian-jira conf install.reg lib logs README.html temp uninstall work
bin external-source jre licenses NOTICE README.txt tomcat-docs webapps
only thing I can find is:
root@libertine atlassian # find . -name *manager-plugin* -print
./jira/temp/plugin.9128344300493221488.atlassian-universal-plugin-manager-plugin-2.7.8.jar
./jira/temp/plugin.4566108212679965318.atlassian-universal-plugin-manager-plugin-2.7.4.jar
./jira/temp/plugin_2277919877510818531_atlassian-universal-plugin-manager-plugin-2.7.10.jar
./jira/temp/plugin.1004167666862049989.atlassian-universal-plugin-manager-plugin-2.7.7.jar
./jira/temp/plugin.6918099885958475159.atlassian-universal-plugin-manager-plugin-2.7.10.jar
./jira/temp/plugin.3400594829461404923.atlassian-universal-plugin-manager-plugin-2.7.6.jar
./jira/temp/plugin_5802223886689695509_atlassian-universal-plugin-manager-plugin-2.7.3.jar
./jira/temp/plugin.186931797163260671.atlassian-universal-plugin-manager-plugin-2.7.10.jar
./jira/temp/plugin.8533881726362717366.atlassian-universal-plugin-manager-plugin-2.7.10.jar
./jira/temp/plugin_281981356399172753_atlassian-universal-plugin-manager-plugin-2.7.10 (1).jar
./jira/temp/plugin.9180641765973393633.atlassian-universal-plugin-manager-plugin-2.7.6.jar
./jira/temp/plugin.6185725129814945694.atlassian-universal-plugin-manager-plugin-2.7.10.jar
just don't know where to pop the new jar file and don't want to break Jira :)
Richard
Pedro Cora
January 10, 2013
Hi Richard,
Looks like you are in the JIRA installation directory and not in the JIRA home directory.
In order to retrieve the location of your JIRA home directory, run the following on your terminal:
cat /opt/atlassian/jira/atlassian-jira/WEB-INF/classes/jira-application.properties
This will get you something like:
jira.home = /Users/xxxx/Atlassian/data/jira524
Then in this directory, you will find the plugins/installed-plugins
Pedro
