×Can the Create transaction by modified to set transitions based on Issue Type? For example, can JIRA send Bugs to the "Bug Backlog" and all other Issues to "Backlog"? I looked in the Create Post Function "Update Issues Field" and "Type" was not one of the options.
You would typically have different workflows depending on the issue type within a project:
Project + Issuetype => Workflow
So, within a project, two issues of different types may share the workflow, but in your case they would have different workflows, i.e. different transition sets.
