You should be able to add custom fields to a Plan from the Plan's settings. It'll also tell you on that screen whether "Planning Version" is a field type which can be added to the Plan, as not all custom field types can be.
To do this:
Once complete, the field should be available for use, both in filtering and to be added as a column.
Ste
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
