Can we add a sprint changed trigger in jira automation?
khushboo_puri
Laurie Sciutti
January 22, 2025
Hello @khushboo_puri ~ if you use ScriptRunner, you can create an automation rule to trigger under these 2 conditions:
  1. when the Sprint Field value changed
  2. JQL condition using the ScriptRunner function, issueFunction in removedAfterSprintStart(board name/ID, [sprint name/ID])
Ref:  https://docs.adaptavist.com/sr4js/8.25.0/features/jql-functions/included-jql-functions/sprint#removedaftersprintstart
Trudy Claspill
January 21, 2025
Are you talking about a change to the Sprint field in an issue?
Or are you talking about some sort of change to a Sprint, like changing the dates of the sprint? If your are talking about this type of change, can you provide more details about the problem you are trying to solve and/or your use case?
khushboo_puri
Hi @Trudy Claspill
We are working on automation and it's needed for adding "removed sprint" label to issues that are pulled out of active sprints
We are trying to see how many stories are pulled out of sprint and label them to track them
