×Hi,
I have execution result in issue format. now i want to append the content to execution result issue into the test case using zephyr plugin
Or Can we add a execution result with all details like status and all to test case issue in bulk instead of manually
Hi Sachin
Thanks for your interest in Zephyr
I have execution result in excel format and i want to add that result to an test case->There is no explicit way to achieve this
We do have APIs to update execution statuses or results via our product called ZAPI. Below is the link that shows our available APIs with regards to executions
Try the link below and navigate to "Execution Resources" In the Left column of the web page
http://docs.getzephyr.apiary.io/#
ZephyrSupport
