  • Community
  • Q&A
  • Jira
  • Questions
  • Can we hide system field like comment , attachments on workflow transition using Groovy, Behaviour etc ?
Sumit Kumar
July 31, 2014
is it possible to hide system fields like comment , attachment etc on workflow transition using behaviuors or any other scripts ?
Thanks in advance,
Sumit
Sumit Kumar
July 31, 2014
I have used behaviour plugin to hide comment field during workflow transition and it works as expected.
Marketa Dvorackova
Hi Sumit, how have you done that? I mean is there a need to write a script for it or there are some config options that I'm not seeing? Need to hide a comment field on just one particular transition screen. Thanks a lot.
gmann February 5, 2015
+2
Sumit Kumar
November 11, 2015
yes this can be easily achieved using behavior plugin on workflow transition. You can also try to use properties in workflow to disable the comment on specific transition but i like behaviour as a good option
Morgan Thunder
Sumit, can you explain how exactly you do this using Behaviours? Do you need to use a custom script?
Alexey_Rjeutski__Polontech_
July 31, 2014
1. As for fields - you can just remove the field from the transition screen and user will not be able to use it during transition.
2. As for comment - you can add transition property that blocks permission to comment:
jira.permission.comment.user=denied
the same for attachment, but you can just don't add attachment field on transition screen. See details on https://confluence.atlassian.com/display/JIRA/Workflow+properties
Sumit Kumar
July 31, 2014
it doesn't work on transition screen.
I tried adding the properties like jira.permission.comment.user=denied
Jira 6.1.7
Sumit Kumar
July 31, 2014
Still have a question about how to work with system attachment field using Behaviour Plugin ?
Like vovkakibe likes this
