Can we provide Jira project access to users using REST APIs?
Prasad_Biddika August 16, 2024
Hi, thanks for your help.
1)Can we provide Jira project access to users using APIs?
2)Can we revoke Jira project access to users using APIs
3)can we know the list of projects that a particular user has using REST APIs?
Please help with the same.
Prachi Bolar
August 18, 2024
Hi Prasad,
Welcome to Community,
Please check this : https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-project-role-actors/#api-group-project-role-actors
This should help you give access via project roles in Jira.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-projects/#api-group-projectsReturns all projects visible to the user)
Thank You,
Prachi
Florian Bonniec
Hi @Prasad_Biddika
User can use the REST API, by default.
If you want to block API usage, I guess you will need an app such as API Token, configure it to only allow API call using Token and block the one using the basic authentication.This app allow also you to manage active token and who can create tokens. It will be valid for the entire instance and not just a project.
Regards
prasad biddika
@Florian Bonniec we want to provide jira projects access using Rest APIs is it possible?
Florian Bonniec
Hi
It will depends how you wan to manage permission, but you could add user to project role with teh REST api.
Jira 9.13.0 (atlassian.com)
Regards
