Can you add a personal task in a comment field?
Ben Kopf
May 30, 2014
I want to be able to use "Insert Task" or [ ] to be able to add tasks to my personal task list as they arise in various comments. Is there a way to do this? Thx
2 accepted
3 votes
Ben Kopf
June 1, 2014
Yes, thanks for responding. I just want to be able to enter my personal tasks into the new Task page without having to create them on a separate page. It's frustrating that I can't just type up a simple task on the Task list. Ben
Shannon S
January 9, 2018
Hi everyone,
I came across this question while searching a more recent one, and I just wanted to mention this feature request:
It's not clear if you saw this, but it is worth watching and voting on to help show the number of users would would like this feature.
Shannon
4 votes
Regis Bondidier June 26, 2014
Is this feature in the Confluence roadmap? It would be create to assign tasks directly from the comments.
Irina_Bel_Stiltsoft_
Hi everyone,
This post seems like water under the bridge, but I would love to mention a solution that addresses this case for those who come across this discussion.
With the idea in mind that certain discussions end up in tasks, we released a new feature in the Talk Advanced Inline Comments app for Confluence Data Center - Talk Tasks. With its help, you can:
  • Assign comments to certain Confluence users to highlight task ownership.
  • Kepp the comments assigned to you (your to-dos) at hand.
  • And track the task resolution that were assigned by you in Talk Report.
Also, not long ago I had a case study with one of our clients who shared how they set up their review process in Confluence. It helps to get the holistic picture on how to use the Talk comments as tasks. However, the article was released before the Talk Task feature roll out. Now,  task management with inline comments is even more intuitive.
Carsten Eider January 28, 2016
We have the same idea. Any updates to this issue or was even a feature request raised?
Bruna Griebeler
May 31, 2014
Hi Ben,
I believe you're talking about tasks in Confluence correct?
As far as I know, this is not possible. So we recommend you to create another task on a subpage, and then link it on a comment for the main page.
