Cannot Fire a custom event
GilK
February 17, 2012
When I edit a transition (any of them) in my workflow and trying to Add a post function, I get a lot of functions but not the function to Fire a custom event, or fire anything.
All the transitions already have JIRA default fire an event post function, but I'd like to add my own.
Any ideas?
Janiv.
JamieA
February 17, 2012
You can fire your own event based on some condition using this workflow function from the script runner plugin.
GilK
February 17, 2012
Works great, thanks !
Jobin Kuruvilla [Adaptavist]
February 17, 2012
JIRA doesn't support mutliple events on the same post function. See https://jira.atlassian.com/browse/JRA-13738 for details.
You can either edit the default event and throw your event instead or catch the event in a listener and throw the custom event. The latter needs development.
MattS
February 18, 2012
You could emulate this by having two statuses. Transition to the first one and fire the first event, then automatically transition to the second status and fire the second status. Perhaps with JIRA Toolkit Auto Transition Listener or using Jamie's approach at http://blogs.onresolve.com/?p=235
Antonio Duarte September 21, 2015
This is an info from 2012. Now, after several versions of JIRA, is it still true that JIRA supports only one 'Fire Event' in the same post-function, or this behaviour has changed? As Janiv, I also need to fire more than one Event in my post-function.
