Cannot access UPM project on studio.atlassian.com
David Corley
April 4, 2012
I used to be able to see all issues in the UPM project on studio.atlassian.com
I can now no longer access the project at all.
We're trying to diagnose an issue we believe may be caused by UPM and we need access to:
https://studio.atlassian.com/browse/UPM/
Is anyone else experiencing this issue?
mtaylor
May 7, 2013
Hi David,
The UPM issue tracker is now located at https://ecosystem.atlassian.net/browse/UPM/
Maleko
Septa Cahyadiputra
April 8, 2012
Hi David,
I have checked the mentioned projects and confirmed that it is currently restricted for Atlassian staff only. Hope this clarifies your doubts.
In regards to your issue, you might want to create a support ticket on our support channel as UPM is a supported plugin.
Septa Cahyadiputra
Learn more
