I am trying to copy the labels on an existing issue to its linked issues (through a certain link).
I am pretty close, but I get an error I'm not sure how to overcome:
import com.atlassian.jira.issue.link.IssueLink
import com.atlassian.jira.issue.label.LabelManager
import org.apache.log4j.Logger
import org.apache.log4j.Level
def issue = event.issue
def labelManager = ComponentAccessor.getComponent(LabelManager)
def existingLabels = labelManager.getLabels(issue.id).collect{it.getLabel()}
def links = ComponentAccessor.getIssueLinkManager().getOutwardLinks(issue.getId())
def subElements = links.findAll { it.issueLinkType.name.contains('Parent/Child') && it.destinationObject.getProjectObject().getKey() == 'TEST'}
subElements.each { it ->
def sublabelManager = ComponentAccessor.getComponent(LabelManager)
def subexistingLabels = sublabelManager.getLabels(it.getDestinationObject().id)*.label
def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
for (eachlabel in existingLabels) {
if (eachlabel && !subexistingLabels*.contains(eachlabel)) {
labelManager.setLabels(loggedInUser, it.getDestinationObject().key, eachlabel, false, false)
The error is:
2019-10-17 07:15:24,744 ERROR [runner.AbstractScriptListener]: ************************************************************************************* 2019-10-17 07:15:24,744 ERROR [runner.AbstractScriptListener]: Script function failed on event: com.atlassian.jira.event.issue.IssueEvent, file: <inline script> groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.label.DefaultLabelManager.setLabels() is applicable for argument types: (com.atlassian.jira.user.DelegatingApplicationUser, java.lang.String, java.lang.String, java.lang.Boolean, java.lang.Boolean) values: [uidq5816(uidq5816), TEST-1001, a2b, false, false] Possible solutions: setLabels(com.atlassian.jira.user.ApplicationUser, java.lang.Long, java.util.Set, boolean, boolean), setLabels(com.atlassian.jira.user.ApplicationUser, java.lang.Long, java.lang.Long, java.util.Set, boolean, boolean) at Script686$_run_closure3.doCall(Script686.groovy:24) at Script686.run(Script686.groovy:14)
Any help is appreciated.
Thank you!
import org.springframework.util.StringUtils
import java.util.Arrays;
import java.util.HashSet;
import java.util.Set;
def log = Logger.getLogger("com.acme.listener")
log.setLevel(Level.DEBUG)
def existingLabels = labelManager.getLabels(issue.id).collect{it.getLabel()} as Set
def subexistingLabels = sublabelManager.getLabels(it.getDestinationObject().id).collect{it.getLabel()} as Set
log.debug("labels on current issue: " + existingLabels)
log.debug("subexistingLabels: " + subexistingLabels)
if (!subexistingLabels.contains(eachlabel)) {
subexistingLabels.add(eachlabel)
labelManager.setLabels(loggedInUser, it.getDestinationObject().id as Long, subexistingLabels, false, false)
Not sure how that can help, it seems I'm just having issues with my last line:
while in there there is a totally different approach.
Thank you.
oh okay anyways if this thing resolves just give out the solution if this is new then it might help others
thanks.
Help us plant more trees
