I met a very strange case that is after I started the JIRA development environment when I want to edit one issue, the page does always stay at the "Loading", from the browser console, I did not see any errors about that.
But when I try to open the same issue (same link to my localhost), the edit issue works and I could see the edit issue screen correctly.
This makes me confused...
Someone kindly helps.
Boyka
I finally found the chrome extension "uBlock origin" did it.
After disable it, funcs work finel
Thank you very very much Boyka!
I had set up a local dev-environment on my localhost machine to develop an app and was struggling with this for a while.
Really cool that you took the time to document the solution here.
BR
Daniel
Learn more
