Cannot edit this issue type in this project
Jerfeson Guerreiro
I can't change the type of my project issue, either existing or new issue, I can choose, but can't change, can anyone help me.
The message is not clear, I did not do what I have to do to resolve.
41 votes
Joseph W_
Settings -> Issues
-> Screens -> (Screen used by your Project) -> Configure
-> (Select Field to add ...) ->"Issue Type"
Then refresh your page and attempt to edit the issue type again!
ricardo verdú December 1, 2020
Thank you Joseph!
Like • Joseph W_ likes this
Lucia Guzman
youre the best!
Alexey Byzov December 3, 2021
Thank you!
Viviane Sasamoto Nunes da Silva
July 17, 2023
Excelent!!
André Felipe Rodrigues Lopes
You are the best!
Afrothiti Manolis
THANK YOU
Kishor Mudhili
it's working as expected. thank you
Erik Santiago
December 3, 2024
GG Joseph!
Rich Witt
April 30, 2025
Thank you! Slight update:   Jira Settings (Top Right) > Work Items > Screens > Configure > Select Field to Add > Issue Type
3 votes
Ewa Mryczko December 30, 2019 edited
I have the same problem. The notification "you cannot edit this issue.." appears only in one my project. I have issue scheme for create, edit and view issue. Also "move"change issue type, but it's not good enough solution for me. How can I change settings to change easily issue type with this favicon?
update - I resolved the problem. I just needed to add "issue type" to configure screen. ;)
Harrold Hummel
April 7, 2020
thanks! this one bugged me for some hours and your solution worked :)
Tatiana Nemchenko
June 27, 2022
Thanks for sharing your quick fix! It solved my problem
Matt Doar
1. Does "move" let you change the issue type?
2.Is the issue type field on the edit screen for the issue (admin question)
Jerfeson Guerreiro
I didn't understand your comments, could it be a little clearer?
Jerfeson Guerreiro
The type of problem was not associated with the screen I had. it was just that.
Sorry, but I think the jira should be clearer in your error messages.
Thanks for your response.
Matt Doar
You're probably right. Not that they are my error messages
Shahar Nissim
Why this field is there anyway? just for this reason?
Renato Silva
January 14, 2024
Your're amazing @Joseph W_ , tks!
