Cannot fetch data from JIRA to excel following suggested approach
sim xing
There is one way suggested in https://community.atlassian.com/t5/Jira-questions/Fetch-data-from-JIRA-to-excel/qaq-p/198786 on how to fetch data from JIRA to excel. While, it doesn't work for me.
I'm using Excel 2013. I don't have "Data menu, New query, From Other Sources, From Web
". Instead, I can only use "Data menu, From Web", which will pop up a window called "New Web Query". I copy paste the file path into the address field.
https://jira.mycompany.com/sr/jira.issueviews:searchrequest-csv-current-fields/30167/SearchRequest-30167.csv
There is no "Basic authentication" to choose from in the window. Only "Go" and "Import" buttons to select. Selecting any of them will pop up a windows asking to open or save the result.
Is that something specific for old version of Excel like 2013, or something related to permission, or I don't have necessary plugin? Thanks!
