×Hello,
I've seen Pie chart here: http://www.atlassian.com/software/bonfire/overview/defect-detection whch shows defects raised by session.
also we would like to create other reports and pie chart to see statistics per Bonfire sessions, create filter which may be used in usual Jira dashboards,
but couldn't find any info in documentation and forum (I saw coupld of same questoins, but they're unanswered)
Example can be:
Session per ticket, bugs per sessions, bugs per tickets under definite filter.
Hi Anna
You can refer on this documentation: https://confluence.atlassian.com/display/CAPTURE/JIRA+Capture+Custom+Fields+and+JQL+commands
It has list down all the custom field that JIRA Capture(Bonfire) has and also some sample JQL filter you can use to retrieve statistical information.
Hopefully it helps :)
