Cannot get rendering on 'text field (multi-line)' to use wiki rendering
jo astley
February 27, 2018 edited
I have configured the fields so that they are set to use the Wiki Style Renderer as default however, it is not applying bullets when using;
* Bullet
** Bullet indented
Please can someone help? I need this for the likes of feature requests etc.
Daniel Wong
February 28, 2018
Hi @jo astley
Just checking that you applied the Wiki Style Renderer on the correct 'Field Configuration' of your project? You can double check this by navigating to Administration » Projects » "Your project", select Fields and edit the Field Configuration for this issue type.
jo astley
Hi, Thank you for answering. I have checked and no it is not showing the correct renderer there. I had changed it for those fields and thought had changed globally but obviously not. Thanks for your help, all working now
Help us plant more trees
