Hi
I´m using a script in post-function to set a value to a customfield ( "Set Field Value Post Function - JMWE app .9.1.0 and Jira DataCenter v.9.12.7
No error occours at Script Runner Console, but running the transaction, I have this message error : "Cannot invoke method newInfoQueryBuilder() on null object" to this code:
Note : This works with Jira 8.
Note2: "SlaInformationService srv = ComponentAccessor.getOSGiComponentInstanceOfType(SlaInformationService)" also worked with Jira 8 but now it says that "Unable to resolve component: interface com.atlassian.servicedesk.api.sla.info.SlaInformationService" BUT not in ScriptRunner Console.
Bug in JMWE ???
import com.atlassian.servicedesk.api.sla.info.SlaInformationService
import com.atlassian.servicedesk.api.sla.info.SlaInformationQuery
import com.atlassian.servicedesk.api.util.paging.PagedResponse
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.servicedesk.api.util.paging.SimplePagedRequest
import com.atlassian.servicedesk.api.util.paging.PagedRequest
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.onresolve.scriptrunner.runner.customisers.PluginModule
@WithPlugin("com.atlassian.servicedesk")
@PluginModule SlaInformationService srv
//SlaInformationService srv = ComponentAccessor.getOSGiComponentInstanceOfType(SlaInformationService)
long idDummy = 1399021//issue.id
PagedRequest pagedRequest
SlaInformationQuery slaQuery
def slaInfo
PagedResponse pagedResponse
SlaInformation[] SLAs = null
pagedRequest = new SimplePagedRequest( 0, 5 )
slaQuery = srv.newInfoQueryBuilder().issue( idDummy ).pagedRequest( pagedRequest ).build()
Hi @Kleber Fonseca,
The JMWE 9.1.1 version includes a bug fix for the 'Set Issue Fields' post function. Do you have this error in the latest version of JMWE?
Read the story
