Cannot reload tests from Atlassian Plugin Test Console
Valentin Borlea January 25, 2015
Hi all,
I want to be able to update unit/integration tests within JIRA Plugin Test Console. The problem is that when I do a change in a test and I scan for tests, JIRA returns an error:
Here is the plugin configuration:
<build>
        <plugins>
            <plugin>
                <groupId>com.atlassian.maven.plugins</groupId>
                <artifactId>maven-jira-plugin</artifactId>
                <version>${amps.version}</version>
                <extensions>true</extensions>
                <configuration>
                    <productVersion>${jira.version}</productVersion>
                    <productDataVersion>${jira.version}</productDataVersion>
                    <useFastdevCli>false</useFastdevCli>
                    <testGroups>
                        <testGroup>
                            <id>jira-integration</id>
                            <productIds>
                                <productId>jira</productId>
                            </productIds>
                            <includes>
                                <include>it/**/*Test.java</include>
                            </includes>
                        </testGroup>
                    </testGroups>
                </configuration>
            </plugin>
            <plugin>
                <groupId>org.apache.maven.plugins</groupId>
                <artifactId>maven-compiler-plugin</artifactId>
                <version>3.2</version>
                <configuration>
                    <source>1.6</source>
                    <target>1.6</target>
                </configuration>
            </plugin>
        </plugins>
    </build>
    <properties>
        <jira.version>6.3.12</jira.version>
        <amps.version>5.0.3</amps.version>
        <plugin.testrunner.version>1.1.5</plugin.testrunner.version>
        <!-- TestKit version 5.x for JIRA 5.x, 6.x for JIRA 6.x -->
        <testkit.version>5.2.26</testkit.version>
    </properties>
It looks like JIRA uses the amps.version for maven-compiler-plugin. That's why I specified a version for it, but it is not taken into account. (at first I didn't specified a version and the groupid for maven-compiler-plugin, but it didn't work too).
Does anyone have a idea how to solve this problem?
dbu
I got the same error. This seems to be a bug in the SDK. I fixed it duplicating the maven-compiler-plugin folder for my version (3.3) in my local Maven repo (~/.m2/repository/org/apache/maven/plugins/maven-compiler-plugin/) under folder name of my AMPS version. Then I replaced all occurrences of the maven-compiler-plugin version 3.3 with my AMPS version. In short: I created a 5.0.13 version of the maven-compiler-plugin in my local Maven repo. It's not nice, but it works. If you update your AMPS, you have to repeat these steps with the new AMPS version.
Mateusz Szafarz May 18, 2015
I have exactly the same error. Can anyone point me what can cause this error? Does anyone use this functionality with success? It's very annoying to have to restart jira after every change made in tests.
Valentin Borlea January 28, 2015
I tried that and it's not working. It seems that fastDev uses <amps.version>5.0.3</amps.version> for maven-compiler-plugin and this version does not exist.
Alexej Geldt
January 26, 2015
why? <useFastdevCli>false</useFastdevCli> remove that line and try again.
