×Hi,
I am able to import CSV data using JIRA CLI and mapped fields and values from an import.properties file. But somehow, the status is always set to "To Do" during import, eventhough I've mapped the status value "processed" (which does not exist in JIRA) to "Done" (which is a status in the bug's jira workflow) in the import.properties file.
field.STATUS1 = status value.status.processed = Done
All other field and value mappings, even more complex ones including breaks, work. Can anyone explain what's the problem about importing status values?
Executing the CLI comand does not give any error messages.
Even renaming the status column in the CSV and adding value "Done" to the column in the CSV directly does not help.
Is there a way to import issues and set the status corretly using JIRA CLI?
JIRA Version: 7.3.1
CLI Version: 6.5.0
Thank you!
Kind Regards,
Sabrina
Hi @SABVARX,
Apologies for the very delayed response as this missed our radar.
Please let us know if this is still an issue. If yes, please respond with the updated JIRA and CLI versions and the problem you are facing.
Going forward, we will do our best in responding to our customer concerns in a timely manner. Just in case you do not receive a response from our team, please contact our customer support directly.
Thank you,
Sudhir
