Cannot start JIRA due to Caught PSQLException for select O_S_PROPERTY_TEXT.propertyvalue
Christian Schlaefcke
August 19, 2016
after a server restart I cannot start JIRA (Version 7.1.9 on PostgreSQL version 9.5.3) anymore. I see a lot of exceptions like this in the logs:
Caused by: com.atlassian.cache.CacheException: com.querydsl.core.QueryException: Caught PSQLException for select O_S_PROPERTY_ENTRY.property_key, O_S_PROPERTY_ENTRY.propertytype
from public.propertyentry O_S_PROPERTY_ENTRY
where O_S_PROPERTY_ENTRY.entity_name = ? and O_S_PROPERTY_ENTRY.entity_id = ?
order by O_S_PROPERTY_ENTRY.id desc
       	at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:207)
       	at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:158)
       	... 27 more
Caused by: com.querydsl.core.QueryException: Caught PSQLException for select O_S_PROPERTY_ENTRY.property_key, O_S_PROPERTY_ENTRY.propertytype
       	at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:50)
       	at com.querydsl.sql.Configuration.translate(Configuration.java:453)
       	at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.lambda$loadPropertyKeysAndTypes$689(CachingOfBizPropertyEntryStore.java:462)
       	at com.atlassian.jira.database.DefaultQueryDslAccessor$1.lambda$executeQuery$149(DefaultQueryDslAccessor.java:79)
       	at com.atlassian.jira.database.DatabaseAccessorImpl.executeQuery(DatabaseAccessorImpl.java:67)
       	at com.atlassian.jira.database.DefaultQueryDslAccessor$1.executeQuery(DefaultQueryDslAccessor.java:78)
       	at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.query(CachingOfBizPropertyEntryStore.java:278)
       	at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.access$200(CachingOfBizPropertyEntryStore.java:71)
       	at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.loadPropertyKeysAndTypes(CachingOfBizPropertyEntryStore.java:456)
       	at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.<init>(CachingOfBizPropertyEntryStore.java:416)
       	at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.loadPropertySetData(CachingOfBizPropertyEntryStore.java:264)
       	at com.atlassian.cache.memory.MemoryCacheManager$3$1.load(MemoryCacheManager.java:162)
       	at com.atlassian.cache.memory.DelegatingCache.lambda$get$0(DelegatingCache.java:158)
       	at com.atlassian.cache.memory.DelegatingCache.lambda$get$1(DelegatingCache.java:186)
       	at com.google.common.cache.LocalCache$LocalManualCache$1.load(LocalCache.java:4742)
       	at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
       	at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
       	at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
       	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
       	at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
       	at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4739)
       	at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:173)
       	... 29 more
Caused by: org.postgresql.util.PSQLException: FEHLER: konnte Block 11 in Datei ?base/16428/105974? nicht lesen: es wurden nur 0 von 8192 Bytes gelesen
       	at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2310)
       	at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2023)
       	at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:217)
       	at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:421)
       	at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:166)
       	at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:83)
       	at com.querydsl.sql.AbstractSQLQuery.fetch(AbstractSQLQuery.java:446)
I already tried to search for a solution but I was not able to get anything helpful out of google when I use the exception details as search term sad
Any hint pointing me in the right direction would be very much appreciated.
Thank you and Regards,
Christian
August 22, 2016
As Chris already stated my issues happened due to disk failures. I have to replace the disk and setup anything from backup. Fortunately the affected instance is just a playground environment and not a heavy load production system smile
August 19, 2016
Hmm, just found out that Postgresql 9.5.x is not supported yet. Maybe this is causing the problems. I will try to downgrade to Postgresql 9.3.x ...
crf
August 21, 2016
Although PostgreSQL 9.5.x isn't officially supported yet (and you should remain on the earlier version to remain on what we support until advised that 9.5.x is okay), it is something that we have started looking at internally, and I don't recall seeing any errors like that come up at any point during the trials.
This looks to me more like an error stemming from corruption of the database itself; that is, this does not look like an problem with the client or server version, but rather a purely server-side error being reported. It may not matter since you'll need to return to a supported database version anyway, but I think you would need to repair the database to have any hope of proceeding.
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
