I'm creating a plugin that runs on jira server 7.13. That plugin will interact with another jira server to do things such as create issue, update issue,...
But when I add dependency of jira-rest-java-client-core, my plugin cannot be started anymore.
My pom file looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.example</groupId>
<artifactId>jrjc-application</artifactId>
<version>1.0.0</version>
<packaging>atlassian-plugin</packaging>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>1.6.6</version>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.sun.jersey</groupId>
<artifactId>jersey-client</artifactId>
<version>1.8-atlassian-16</version>
</dependency>
<dependency>
<artifactId>jersey-core</artifactId>
</dependency>
<dependency>
<artifactId>jersey-json</artifactId>
</dependency>
<dependency>
<artifactId>jira-rest-java-client-api</artifactId>
<version>5.1.0</version>
</dependency>
<dependency>
<artifactId>jira-rest-java-client-core</artifactId>
</dependency>
<dependency>
<groupId>com.atlassian.fugue</groupId>
<artifactId>fugue</artifactId>
<version>2.6.1</version>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>jira-maven-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<applications>
<application>
<applicationKey>jira-software</applicationKey>
</application>
<application>
<applicationKey>jira-servicedesk</applicationKey>
<version>${jira.servicedesk.version}</version>
</application>
</applications>
<enableQuickReload>true</enableQuickReload>
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package/>
<!-- Add package import here -->
<Import-Package>
org.springframework.osgi.*;resolution:="optional",
org.eclipse.gemini.blueprint.*;resolution:="optional",
com.atlassian.inject;resolution:="optional",
com.sun.xml.fastinfoset.*;resolution:="optional",
groovy.*;resolution:="optional",
joptsimple;resolution:="optional",
net.sf.ehcache;resolution:="optional",
net.spy.memcached;resolution:="optional",
org.*;resolution:="optional",
sun.misc;resolution:="optional",
</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>7.13.1</jira.version>
<jira.servicedesk.version>3.16.1</jira.servicedesk.version>
<amps.version>8.0.0</amps.version>
<plugin.testrunner.version>2.0.1</plugin.testrunner.version>
<atlassian.spring.scanner.version>2.1.8</atlassian.spring.scanner.version>
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<testkit.version>6.3.11</testkit.version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
</project>
And this is error message in jira log when I install the plugin:
ThreadPoolAsyncTaskExecutor::Thread 24 ERROR [o.e.g.b.e.i.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.example.jrjc-application], unsatisfied dependencies: none
org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: Unable to locate Spring NamespaceHandler for XML schema namespace [http://www.atlassian.com/schema/atlassian-scanner/2]
Offending resource: URL [bundle://273.0:0/META-INF/spring/plugin-context.xml]
at org.springframework.beans.factory.parsing.FailFastProblemReporter.error(FailFastProblemReporter.java:70)
at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:85)
at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:80)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.error(BeanDefinitionParserDelegate.java:301)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1408)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1401)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:168)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.doRegisterBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:138)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:94)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:508)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:392)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:336)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:304)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:181)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:217)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:188)
at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:170)
at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:140)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:129)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:609)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$800(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$3.run(AbstractDelegatedExecutionApplicationContext.java:242)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.startRefresh(AbstractDelegatedExecutionApplicationContext.java:220)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:224)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:177)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:157)
at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager$1.run(LifecycleManager.java:207)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
I did some dependency exclusions in maven to resolve this problem.
To be able to use JRJC in your add-on for JIRA (version 7.13.0 in my case), you only need to use jira-rest-java-client-core, don't need to put others dependency such as jersey or jira-rest-java-client-api (core part will pull this dependency later for you), and then do dependency exclusions as the following code to exclude conflict dependencies from your add-on (as JIRA already provided it).
<dependency>
<version>5.1.2-2bd0a62e</version>
JIRA will already provide a number of dependencies that JRJC needs. We need to exclude
them from the JRJC dependency as we don't want to package them up inside the plugin.
<exclusions>
<exclusion>
</exclusion>
<exclusion>
</exclusion>
<exclusion>
<groupId>joda-time</groupId>
<artifactId>joda-time</artifactId>
</exclusion>
<exclusion>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
</exclusion>
<exclusion>
<groupId>com.atlassian.event</groupId>
<artifactId>atlassian-event</artifactId>
</exclusion>
<exclusion>
<groupId>org.springframework</groupId>
<artifactId>spring-beans</artifactId>
</exclusion>
<exclusion>
<groupId>org.apache.commons</groupId>
<artifactId>commons-lang3</artifactId>
</exclusion>
<exclusion>
</exclusion>
</exclusions>
</dependency>
Then do some additional exclusions in the dependency of jira-api:
<dependency>
<exclusions>
<!-- JRJC depends on a newer version of dependencies than the one provided by JIRA -->
<exclusion>
<groupId>io.atlassian.util.concurrent</groupId>
<artifactId>atlassian-util-concurrent</artifactId>
</exclusion>
<exclusion>
<groupId>com.atlassian.httpclient</groupId>
<artifactId>atlassian-httpclient-library</artifactId>
</exclusion>
</exclusions>
</dependency>
Last part, you need to import packages that your plugin will use in <Import-Package> part:
<Import-Package>
</Import-Package>
@Nhac Tat NguyenYour comment was really useful as I struggle with this at a Bamboo Plugin. It helps me to find the right direction :)
Hi @Nhac Tat Nguyen ,
I might not be the best person to help here, but it looks like the same error message (Unable to locate Spring NamespaceHandler for XML schema namespace [http://www.atlassian.com/schema/atlassian-scanner/2]) has been discussed in the below threads:
Please review above threads and see if they help. Plus, in case you haven't seen it already, you may also want to have a look at:
Finally, in case of no luck, you can always ask the same question in the developers' community or open a service request with the ecosystem team:
I hope this helps.
Dario
Hi @Dario B
Thanks for you quickly and kindly support.
I have looked at the link you gave me at:
And that was my problem - dependencies conflict.
The JRJC library use some dependencies that is already supplied by JIRA, and those conflicting resource was erroneously bundled in my plugin.
I did some dependency exclusions in maven, and everything works as expect.
Again, thanks a lot for your kindly support!
Nhac Tat Nguyen
You are very welcome @Nhac Tat Nguyen and I am happy to know that I was able to help in here! :)
Have a nice weekend,
Dario
