Sign up Log in
Cascading Insight Object Picker
Robin Weiß June 14, 2019
Hey,
it ist possible to configure an cascading Insight Object picker for Jira Service Desk?
I 'd like to have one on our Customer Portal.
First field is e.g. Room and the second is Desk so you can only select Desks in the room you choose bevor.
I would have an Insight Matrix containing a room object type with an Field containing all desks in this room.
Could You suggest a solution?
Do I have to configure a new field type?
Thanks for your help beforehand.
Greetings Robin
Ilya Turov
June 14, 2019
Ilya thanks a lot for the quick answer.
It seems to be my solution.
I will try it out in the next days.
Rodolfo Romero - Adaptavist
Hi Ilya, the link doesn't seem to be working anymore.
Ilya Turov
April 24, 2020
@Rodolfo Romero - Adaptavist
yeah, they've changed their site. but googling "Referenced Insight Custom Field" still works:
https://documentation.mindville.com/insight/latest/referenced-insight-custom-field-33466889.html
Like Consulente Atlassian likes this
