I need some guidance how to set up a cascading select where the values are populated from a SQL table. I don't want do do an import, I know I have that possibility with Scriptrunner.
I have the following parent/child fields, Activity and Sub-activity. There are about 80 activities and 100 sub-activities. In total I get about 2200 combinations. I could just create a cascading select but then I need to maintain the 2200 combinations :-(
So, now I'm thinking if it is possible to dynamically populate my fields from a SQL-table? Any suggestions where to start? Do I need a plugin? Any recommodations? Could it be done with scriptrunner? And as usual, performance is always an important issue. My users don't want to sit and wait looking at a spinner.
Hello @Mattias Kallvi
I have personally tried this for single select list and not cascading list.
Using script runner, here's the why to do it for single select list
For your requirement this is a specific paid plugin as well for fetching data in custom field from various datasources including DB
Hello @Tarun Sapra
Thanks for your answer. I have looked at Elements Connect plugin before to display custom user properties from LDAP. Maybe it's time to pick it up again :-)
The scriptrunner-way, is there some way of trigger the SQL-query based on changes in the form? For example, when user chooses Activity 1, query SQL table for sub-activities to Activity 1. Could Behaviours be used? Any other suggestions?
