Change CSS through web item
Kathleen Jacobs
I'm trying to create a plugin that selecting a web-item toggles some CSS.
I was able to set it up so selecting the web-item from the drop down would trigger an alert popup.
But when trying to add CSS, it doesn't seem to work. Just takes me back to the home page.
My JS file for testing:
AJS.toInit(function(){
AJS.$('#website_link').click(function(){
document.getElementById('jira').style.backgroundColor = "blue";
 called by:
<web-section key="my_links_section" name="My Links Main Section" location="my_links_link" weight="10"/>
<web-item key="my_links_link" name="Link on My Links Main Section" section="system.top.navigation.bar" weight="47">
<label>My Company</label>
<link linkId="my_links_link"/>
</web-item>
<web-item key="website_link" name="Company Web Site" section="my_links_link/my_links_section" weight="10">
<label>Web Site</label>
<link linkId="website_link"/>
</web-item>
Bryan Robison
You need to add a "return false;" to your click handler to prevent the default link behavior:
return false;
Kathleen Jacobs
It stopped refreshing and taking me to the home page, but still not seeing the CSS change :/
Bryan Robison
What element(s) are you trying to change? I'm not aware of any HTML elements with the id of "jira"
Kathleen Jacobs
got it working! Thanks!  Had to find a different element i guess
Javier Portillo
May 23, 2018
If you are talking about an issue web-item I would create an empty issue section and include there all the to the js staff
Hope it helps
Kathleen Jacobs
This is a dropdown list web-item
