Change Issue Status Based on Date Field
Kevin Seery
I have a custom field 'Renewal Date" I'd like to change the status of the issue based on this date. ie compare current date to renewal date if within 45 days change status to 'Renew'
Is this possible in JIRA?
Many Thanks
Kevin
Alexey Matveev
October 31, 2017
You can use plugin Automation Lite for Jira. It is a free plugin.
You can define there a trigger which will be a scheduled event. This event regularly will choose issues based on JQL query which you will provide. For example JQL query could be like this "Renewal Date" < startOfDay(-45d). And then you will choose an Action which must be done on such issues. In your case it will be transition issue.
I think it would solve your problem.
Kevin Seery
Hi Alexey,
Thanks for your answer, sounds mad but can use the Add-on due to corp rules.....
Many Thanks
Kevin
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
