Change JIRA cookie name to JIRASESSIONID instead JSESSIONID
Sergey November 7, 2018
KellyW
November 7, 2018
Hi Sergey,
You can change the cookie name to JIRASESSIONID by updating the 'sessionCookieName' <JIRA_INSTALL>\conf\context.xml. Example:
<Context sessionCookieName="JIRASESSIONID">
<!-- Default set of monitored resources. If one of these changes, the -->
<!-- web application will be reloaded. -->
<WatchedResource>WEB-INF/web.xml</WatchedResource>
<WatchedResource>${catalina.base}/conf/web.xml</WatchedResource>
<!-- Uncomment this to disable session persistence across Tomcat restarts -->
<Manager pathname="" />
</Context>
 Save the changes and restart JIRA.
Kelly
Alexey Matveev
November 7, 2018
Kindly have a look at this ticket
https://jira.atlassian.com/browse/JRASERVER-62400
You can find a solution there.
atlassian, state of product 2026, product teams report, developer experience, product manager survey, AI impact, product team stress, product teamwork, dev workflow insights, 1000+ PMs, product leadership research
State of Product 2026
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
