Change issue type automatically on transition.
siva
Tried to change the issue type when a transition is done to a workflow,
used BOB swift addon :
 Update issues post function from Update on Transition for JIRA
but doesnt work as expected, the issue type doesnt change.
we even use JIRA SUITE UTILITIES
any suggestion to make this happen.
Nic Brough -Adaptavist-
September 21, 2018
ScriptRunner can also do it.
But you might be better off debugging the problem you have with the existing process you're trying.
Very simple question here - are the two issue types you are moving between identically configured?  Same workflow, field configuration, and fields?
If they are not, then you can't just change the issue type, as you need to check the issue data fits the new shape of the issue and alter it to match.
That is not something you can do in a transition because you might be removing the transition that you're currently running.
Dave Bosman [Realdolmen]
September 20, 2018
HI  @siva
I suggest you try Automation for JIRA
Very easy to create automation tasks that can handle what you need, and more, a lot more.
Regards
Dave
siva
Thank you, but any other option other than the automation for Jira, with Bob swift or JSU
Ron Chan December 3, 2020
We use this add-on but changing the issue type is not an option
Mike McNamara
I can do this successfully using Automation. For us, there is no concern regarding how the change may impact fields, workflow, etc. as this workflow is for a business process and the issue type helps define different types of the same activity.
October 6, 2021
Yep, it'll work when the two issue types are configured the same way.
Register Now
