×Jira, I'm able to adjust the layout of new tickets but the layout is not changed for existing tickets. I've updated the tickets and it doesn't have an impact on the layout as well.
What do I need to do to update the layout on existing tickets? It's working for new tickets but not existing ones.
All...I went ahead and submitted a ticket with Atlassian and they confirmed that you can rearranged a screen layout fields and they will apply to any ongoing issues. Existing issues will not use the new layout.
I think you update the issue screen scheme for create operation only not for edit/view
please check in the project summary the linked issue screen scheme and updated the linked screen to edit/view operation accordingly to be as same as the create one
Mohamed Megahed
I've tried doing that and it's showing the screen layout correctly as updated. Going to the Screens, Configure Screen, selecting the screen template and it's showing the field layout correctly.
Can you specify the specific steps to get there?
You can go to Project Settings ---> Summary ---> Screens -- > select the screen scheme you like to update then check the associated screen with View/Create/Edit operations and be sure all are updated according to your requirements
something should be like the below and you update the screens
Yes, that's where I'm going and all of the layouts...Create/Edit/View Issue all show the same layout but the existing records are still updated based on the rearranging of fields.
Can I see example of the existing ticket and the new one and your configuration for screen scheme
View on existing records...project wanted the Acceptance Criteria field moved below descritpion:
Layout for a new record, the field Acceptance Criteria shows correctly moved below description
There is nothing play with the order or the fields except the screen scheme for view/create operation. I would recommend to double check if it doesn't work I'm really sorry but I can't provide more help :(
