Change of labels does not show in history
Patrick Schindler
Apparently, a change in labels for a page does not show up in the history of a page, because no new version is created as with all other changes on a page.
The result is that if you delete a label, there is no way of going back, because there is no undo function.
What would be a good workaround?
Patrick
Andrii Tkachenko _BeastieHut_
Hello @Patrick Schindl . Can you please tell if you found the solution or the question is still actual?
JarkkoR
August 7, 2016
Did you find an answer to this? We are in the need to see what labels has been deleted in a space for a lot of pages and I'm wondering if that can be found anywhere.
Hello @JarkkoR.
Could you please tell if you succeded to find the solution ?
Register now
