We have subtask with status : A traiter, En cours, terminé
When a subtask is in status "A traiter", and a user add Timespent, we want to change automatically the status in "En cours",
Can you help me on this topic please ? I don't find other topics for this.
Best regards
Jérôme
You can review jira automation which can perform what you are looking for. Link: https://www.atlassian.com/software/jira/features/automation
Trigger: Issue Transition to "A Traiter'
Condition: Whatever you need to refine the scope
Action: transition issue to "En Cours".
I hope this helps.
Thanks for your help, but we must have Pro for this solution , we have only Lite
Hi @Jérôme Arpin and welcome to the community!
As you are on Cloud you should have the Automation for Jira available to you.
With that you can create a simple automation rule to transition the issue/subtask to another status when you "log work"
for example something like:
Thanks for your answer
but We have JIRA Server and automation Lite, Can we do like that too ?
I see, you posted this question under Cloud and that has a build in automation (the pro version for Server)
It seems the Lite version cannot work with the trigger "Work Logged"
https://confluence.atlassian.com/automation/getting-the-right-version-993924597.html
