Change the Confluence color scheme via SQL or some other automation
Jason Friedman
January 16, 2014
From time-to-time we copy our PRD data down to a non-PRD instance. We then manually update the non-PRD color scheme so that we don't mistakenly work in the wrong environment.
We would like to be able to make this change via SQL or some other automation. We recognize this might be risky in a PRD environment, but we would be applying this change to non-PRD only.
Jozef Kotlár
February 13, 2014
Look to bandana table:
select * from bandana where bandanakey = 'atlassian.confluence.colour.scheme' and bandanacontext = '_GLOBAL';
Jason Friedman
February 13, 2014
Yep, thanks, that is what we ended up doing.
echo "update bandana set bandanavalue = '<colourScheme> <colours> <entry> <string>property.style.topbarmenuselectedbgcolour</string> <string>#999999</string> </entry> <entry> <string>property.style.menuitemselectedbgcolour</string> <string>$COLOR</string> </entry> <entry> <string>property.style.spacenamecolour</string> <string>#999999</string> </entry> <entry> <string>property.style.navtextcolour</string> <string>#ffffff</string> </entry> <entry> <string>property.style.linkcolour</string> <string>#330066</string> </entry> <entry> <string>property.style.navselectedtextcolour</string> <string>#ffffff</string> </entry> <entry> <string>property.style.breadcrumbstextcolour</string> <string>#111111</string> </entry> <entry> <string>property.style.menuitemtextcolour</string> <string>#535353</string> </entry> <entry> <string>property.style.headingtextcolour</string> <string>#000000</string> </entry> <entry> <string>property.style.topbarcolour</string> <string>$COLOR</string> </entry> <entry> <string>property.style.navselectedbgcolour</string> <string>$COLOR</string> </entry> <entry> <string>property.style.navbgcolour</string> <string>$COLOR</string> </entry> <entry> <string>property.style.bordercolour</string> <string>#999999</string> </entry> <entry> <string>property.style.menuselectedbgcolour</string> <string>#999999</string> </entry> <entry> <string>property.style.topbarmenuitemtextcolour</string> <string>#999999</string> </entry> <entry> <string>property.style.menuitemselectedtextcolour</string> <string>#ffffff</string> </entry> <entry> <string>property.style.topbarmenuselectedtextcolour</string> <string>#111111</string> </entry> </colours> </colourScheme>'where bandanacontext = '_GLOBAL' and bandanakey = 'atlassian.confluence.colour.scheme';" | psql confluence
Jason Friedman
January 16, 2014
Learn more
