Change the display of multi select fields in jira's admin tabs
Laurent Bierge
May 16, 2019
I am a bit annoyed by one feature in Jira. In several administration tabs (context of custom field, priority scheme, ...) there are multi select fields that allow you to select multiple project.
Like this one :
However, those fields are very annoying to use since, according to my experience, you must hold [CTRL] will selecting another choice. Scrolling is a real pain, the field only display 5 project at once. You can't search a project by typing a letter since it will deselect your previous selection.
Is there a way to improve this field (dark features, higher version ? i'm in 7.11.2, ...) in order to make it less painful to use ?
Laurent
Brant Schroeder
You can go here and make a product feature suggestion: https://jira.atlassian.com/secure/Dashboard.jspa?selectPageId=10440
I searched the current suggestions and this is what I found https://jira.atlassian.com/browse/JSWSERVER-20039?jql=project%20%3D%20JSWSERVER%20AND%20type%20%3D%20Suggestion%20AND%20statusCategory%20!%3D%20Done%20AND%20summary%20~%20%27Context%27%20ORDER%20BY%20Updated
You should vote for the one that looks like it is in relation to what you want or create a new suggestion.
