Changes in atlassian-plugin.xml require JIRA restart
Viktor Kuzmychov
October 27, 2017 edited
Hi everyone,
I am developing a JIRA report plugin and I need to add another property (field) into report configuration page. However after I do that, I have to restart JIRA for changes to take effect. I can survive this while development, however restarting live system for just installing new version of a plugin seems to be too much.
How can I solve this? Non of plugins from market requires this, so there must be a way.
For your reference, I've tried so far:
  1. Changing plugin version in pom.xml
  2. Ctrl+F5 on plugin management page
  3. Deleting/installing plugin from scratch
Non of that works. I've seen a lot of questions on the subject, but there were no solutions.
Here is my atlassian-plugin.xml:
<atlassian-plugin key="${atlassian.plugin.key}" name="${project.name}" plugins-version="2">
<plugin-info>
<description>${project.description}</description>
<version>${project.version}</version>
<vendor name="${project.organization.name}" url="${project.organization.url}"/>
<param name="plugin-icon">images/pluginIcon.png</param>
<param name="plugin-logo">images/pluginLogo.png</param>
</plugin-info>
<!-- add our i18n resource -->
<resource type="i18n" name="i18n" location="report2"/>
<!-- add our web resources -->
<web-resource key="report2-resources" name="report2 Web Resources">
<dependency>com.atlassian.auiplugin:ajs</dependency>
<resource type="download" name="report2.css" location="/css/report2.css"/>
<resource type="download" name="report2.js" location="/js/report2.js"/>
<resource type="download" name="images/" location="/images"/>
<context>report2</context>
</web-resource>
<report name="Monitor Report" i18n-name-key="monitor-report.name" key="scope-monitor-report" class="com.reports.jira.reports.Monitor">
<description key="monitor-report.description">Monitor Report</description>
<resource name="view" type="velocity" location="/templates/reports/monitor-report/view.vm"/>
<resource name="view.css" type="download" location="css/view.css"/>
<resource name="i18n" type="i18n" location="MonitorReport"/>
<label key="monitor-report.label"/>
<properties>
<property>
<key>build</key>
<name>monitor-report.build.name</name>
<description>monitor-report.build.description</description>
<type>select</type>
<values class="com.reports.jira.reports.BuildParamsValuesGenerator"/>
</property>
<property>
<key>bsa</key>
<name>monitor-report.bsa.name</name>
<description>monitor-report.bsa.description</description>
<type>user</type>
<values class="com.atlassian.jira.issue.customfields.impl.UserCFType"/>
</property>
</properties>
</report>
</atlassian-plugin>
kyona
May 15, 2019 edited
Hello everybody,
I have the same issue, report configuration page is not updated after its code has been changed. I am tried to remove the cache, update report version, did full reindexing, nothing works for me (only Jira restarting). Looks like a Jira bug...
Have anybody solved this issue already?
kyona
Seems there is a workaround for reloading reports without Jira restart:
https://community.atlassian.com/t5/Answers-Developer-Questions/Adding-fields-before-generating-report/qaq-p/507482
I did not tried this yet, but hopeful it works.
Daniel Wester
November 21, 2017
How are you developing it? Are you using atlas-run/debug in the sdk? That should be by default disabling caching (which it sounds like you're hitting).
Viktor Kuzmychov
Hi Daniel,
No, I use atlas-package and then install target jar onto my JIRA instances.
Viktor Kuzmychov
Anyone? Any help? Pleeeaaase....
Viktor Kuzmychov
An update:
If I install a newer version of the plugin, the source code is being updated, but the configuration form of the plugin not. E.g. as I'm adding a new property and do some checks in code, I get an error as there is no parameter specified in the URL, but it is expected in the code. So if I add parameter to the URL, I get result from the new code.
Example:
it looked like this before:
ConfigureReport.jspa?build=REL-43&selectedProjectId=11012
And when I press Next after report configuration I get NullPointerException.
So now it should look like this:
ConfigureReport.jspa?build=REL-43&bsa=&selectedProjectId=11012
OR
ConfigureReport.jspa?build=REL-43&bsa=georgie&selectedProjectId=11012
and I get correct results.
Tayyab Bashir
October 27, 2017
Often times cache keeps serving changes from the previous versions.
(Although this happens to me after when dealing with changes in JavaScript)
But you could still try by deleting all the cached files and images from your browser to see if it picks up the changes or not.
Viktor Kuzmychov
Thanks for your reply. Actually I already tried this already and just in case tried it again right now. It doesn't help.
Help us plant more trees
