Changing server ID in JIRA
DanielG
June 2, 2013
I follow this documentation:
https://confluence.atlassian.com/display/JIRAKB/Changing+Server+ID+for+Test+Installations
I put this query on my database in JIRA, with ID that I want:
UPDATE propertystring SET propertyvalue = '<ID>' where id = (select id from propertystring where id in (select id from propertyentry where PROPERTY_KEY='jira.sid.key'));
But return this error:
ERROR 1093 (HY000): You can't specify target table 'propertystring' for update in FROM clause
Can anybody help me ?
I can't change my server ID of my JIRA :(
5 votes
DanielG
June 3, 2013
Finally, this was the sentence SQL that I used to change my Server ID on JIRA:
UPDATE propertystring SET propertyvalue = 'XXXX-XXXX-XXXX-XXXX' where id= XXXX
You have to search which ID you have to change with query:
select * from propertystring where id in (select id from propertyentry where PROPERTY_KEY='jira.sid.key');
Mikhail T
MySQL does not allow modifying tables, that are mentioned in subqueries of the UPDATE. So rephrase your update to avoid subqueries. Something like (untested):
UPDATE propertystring, propertyentry SET propertyvalue = 'XXXX-XXXX-XXXX-XXXX' WHERE propertstring.id=propertyentry.id AND propertyentry.PROPERTY_KEY='jira.sid.key'
Test the query with SELECT instead of UPDATE. Yes, you can list multiple tables in UPDATE even if you are only modifying some of them...
Timothy
June 2, 2013
Your SQL query must be wrong and may need the extra schemas/domain included with the table name. Fix it.
DanielG
June 2, 2013
I test:
And works, return:
ID | property value
10006 | XXXX-XXXX-XXXX-XXXX
I test this:
UPDATE propertystring SET propertyvalue = 'XXXX-XXXX-XXXX-XXXX' where id in (select id from propertystring where id in (select id from propertyentry where PROPERTY_KEY='jira.sid.key'));
And not works... I get the same error... why??
Robert Mota
Why to put in addition "select id from propertystring where id..."
Is it not simpliest as below ?
where id in (
Best regards
Bhushan Nagaraj
June 2, 2013
DanielG
June 2, 2013
Don't work for me. I still get the same error...
Zul NS [Atlassian]
June 2, 2013
Need someone who is good in MSSQL on this. Quick search lead me to this and this link.
Register now
