Following the change of the name of the Team, we would like to modify the project key so that it will also reflect the new team name.
Currently there are 3'000 tickets in the "old" board.
Is changing the key truly harmless, like just edit the project settings, rename, then save?
Any tips/experiences with this amount of tickets?
The instructions say: "Editing a project key is not a trivial task. You should choose key that will suit your long-term needs when creating a project, rather than rely on editing the project key after the project is created. However, there are situations where you need to change the key for an existing project, e.g. change of product name."
Thanks in advance for your help.
Hi @[deleted]
Welcome to the Community!!
The effects are
Here's the full doc
https://support.atlassian.com/jira-cloud-administration/docs/edit-a-projects-details
Pramodh
Thank you so much for such a fast reply. So this means that we don't have to migrate the old tickets but these will automatically remain on the renamed board?
Hi @[deleted]
Look at this posts, maybe can help you
https://confluence.atlassian.com/adminjiraserver/editing-a-project-key-938847080.html
https://confluence.atlassian.com/jirakb/how-to-handle-project-key-pattern-change-318668919.html
Cheers
Thank you very much for your help. I am a user, not a technical person. So I am a bit lost with all that documentation :-)
