I've created a new transition named: reopen issue, which reopen an issue usch as: task or story.
However, the button title is 'Stop Progress' (the description is fine: reopen an issue).
When I go to the transition properties I can find the following propety key & value:
jira.i18n.title - stopprogress.title
How do I rename the title from 'Stop Progress' to 'Reopen Issue'?
Janiv.
Just delete the property and the button should reflect the name of the transition.
There is a little documentation about this here - http://confluence.atlassian.com/display/JIRA044/Configuring+Workflow#ConfiguringWorkflow-CreatingaWorkflow
I think this answer can help you
I had the same question...look for this in the documentation
 If you are copying the default workflow (above) and wish to rename the workflow transition buttons on the 'View Issue' page, you must delete the
 If you are copying the default workflow (above) and wish to rename the workflow transition buttons on the 'View Issue' page, you must delete the jira.i18n.title and jira.i18n.description properties from all transitions in the copied workflow. Otherwise, the default names (i.e. values of these properties) will persist. Read more about transition properties.
I could not locate the answer in the documentation provided. It should be a straight forward setting somewhere. A button (for example "assign" button), if it has to be renamed to "assign to developer" or "change owner", then there should be a simpler way to do it.
If you have the solution, please share it.
