Is it possible to change the fields that display within the 'Issues in Epic' list when viewing an epic? I have a custom field on issues for team assignment (we have multiple sub-teams within the project), and it would be really helpful to display this next to each of the issues where they are listed on the epic issue ticket.
Rob
Put this into announcement banner (remember the change the custom field id in the script):
<script type='text/javascript'>
AJS.$(document).ready(function() {
AJS.$('#ghx-issues-in-epic-table tr').each(function(){
console.log('Found epic table');
var row = this;
var issueKey = AJS.$(this).attr("data-issuekey");
AJS.$.getJSON(AJS.contextPath() + '/rest/api/latest/issue/' + issueKey, function(data){
console.log('Got data for - ' + issueKey);
var value = data.fields.customfield_10600;
console.log('Value - ' + value);
var actions = AJS.$(row).find('td.issue_actions');
AJS.$(actions).before('<td class="nav">' + value + '</td>');
</script>
Thanks for the help! Unfortunately I'm using a hosted version of Jira so it seems that scripts have been disabled.
Hi Elizabeth ,
Did you figured it out where to use these scripts?
