Changing the set of values in one custom field depending on selected value
Meenakshi
September 14, 2015
I have a custom field A of type multi-select. And there is another custom field B of type multi-select. I want that on selecting a value of custom field A , the set of values to choose from the custom field B gets modified. Is there a way to do that?
I am using JIRA v7.0 and cannot find the Multi-Level Cascading Select plugin in it.
Nic Brough -Adaptavist-
September 14, 2015
When you say you're using JIRA 7, do you mean Early Access (not suitable for production use) or Cloud (where you can't install that addon anyway)?  As far as I can tell, the add-on has not been updated for version 7 anyway, so you'll have to wait until it is.
