Chart error after upgrade to 7.7.2
Wikpol March 15, 2018
Hi all
I've found this error with all my charts in all projects , look like some add-on was deleted  but nothing seem to be connected with charts when I look at my add-ons list from previous versions. Look at the top of my chart. It used to look different
Tinker Fadoua
Hi Wikpol
Are you still having this issue?
Wikpol March 25, 2018
Since there Is no answer :D YES ,yes I do
Tinker Fadoua
Sorry to hear that Wikpol.
Did you take a look at the logs? What are you seeing?
Did you run the JIRA Update Check before the upgrade?
This is an Agile Chart, may be something to do with a system macro. Any details you can provide will be useful to give you some guidance.
Thank you!
Wikpol March 28, 2018
Heh... to be honest I missed that function :D always been doing it manually by analyzing documentation.
Since it stand on Windows system it may be a Windows based core issue ? But that's a long shot.
I do not know how to analyze logs . Maybe some guidence??
Tinker Fadoua
Ok let me get you the info that will help you.
Tinker Fadoua
Learn more
