Check in which workflow condition and postfunction certain field is used
Michael Partyka
March 22, 2016
I would like to check in which workflow condition and postfunction certain field is used.
Is it possible in easy way?
3 votes
Tibor Hegyi [META-INF]
I don't think there is an easer way of checking this besides exporting the workflow to XML and searching for the field's name in the XML content.
System fields with name (e.g. summary, description, etc) and custom fields with key ("customfield_12345") will appear in the xml.
Tibor
Christian Czaia [Decadis AG]
March 23, 2016
Tibor is right. You might find it easier to just query the DB as it stores the XML-Files in the JIRAWORKFLOWS table
Cheers
Ligia Merciu
Hi Michal,
I may be a little late, but you should try the Workflow Viewer in JJUPIN and look for the customfield either by id or by alias.
Ligia
