Hello
I want to check a radio button value with a groovy script.
My radio button custom fiel ID is 15002, can have 3 choose : none, oui, non.
If value is on "yes", I want a true return
Here the script I wrote, but don't work
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.Issue;
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject("customfield_15002")
def value = issue.getCustomFieldValue(customField);
if (value == "oui")
return true
Any help ?
Hi @cendre Please try below code.
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.CustomFieldManager
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
IssueManager issueManager = ComponentAccessor.issueManager
MutableIssue issue = event.issue as MutableIssue
if (value == "oui")
return true
I try with this code, and it's work
CustomField radioButton = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Configuration ?");
if(radioButton == null)
return false
if(radioButton.getValue(issue).toString().equals("oui"))
return true
else
return false
Thank @Subrat Mishra for your help
FWIW that solution doesn't seem to work with Behaviors. This is testing well today, both get and set. Some bonus code to get the Priority value.
import com.atlassian.jira.issue.IssueConstantImpl
def priorityField = getFieldById(fieldChanged)
def priorityFieldValue = priorityField.value
def selectedPriority = ((IssueConstantImpl) priorityField.value).name
def impactField = getFieldByName("Impact")
def selectedImpact = impactField.value
log.error("=====> Priority:" + selectedPriority + " Impact:" + selectedImpact)
if (selectedImpact == null) {
switch (selectedPriority) {
case "Low":
impactField.setFormValue("This issue is minor in nature.")
break
Context: We will set Priority based on a custom Impact radio button group. That code attached to Impact works fine for new issues. Today's task is to cut this into production and not bulk change thousands of old issues. Instead this code attached to Priority handles if Impact is null we need to set it according to Priority. Wish me luck.
