I have a checkbox custom field and it has 5 options. I want all the 5 options to be required. How do I make sure the user has selected all options before submitting the form. How do i make all the options as required ? All we have now is a field as required but how do we make the options as required ?
Solution and I fixed it.
Created a validator in workflow on create issue. Used built in script runner to check a customfield checkboxes values. All the checkbox field is required field. All the checkboxes need to be selected to create an issue.
cfValues['Please acknowledge'][0].getValue() == 'option1' cfValues['Please acknowledge.'][1].getValue() == 'option2'
cfValues['Please acknowledge'][2].getValue() == 'option3'
cfValues['Please acknowledge.'][3].getValue() == 'option4'
Thank you for your suggestion.
You'll need a validator to do that in workflow.
The standard "mandatory" field stuff will accept any one (or more) options being selected as "this has been filled in".
I tried to add a validator on create issue and mentioned by conditions as
cfValues['Please acknowledge'][0] == 'Yes' cfValues['Please acknowledge.'][1] == 'Yes'
cfValues['Please acknowledge'][2] == 'Yes' cfValues['Please acknowledge.'][3] == 'Yes'
It validates the checkboxes but it won't let me create the issue. I am getting the error message when i click create issue button , please select all the checkboxes .
What am i doing wrong. Please help me out.
I see this message in logs
2012-08-13 13:06:38,785 TP-Processor8 ERROR user 786x13496x1 16q0vol 10.203.201.222 /secure/QuickCreateIssue.jspa [groovy.canned.utils.ConditionUtils] javax.script.ScriptException: java.lang.NullPointerException: Cannot invoke method getAt() on null object
2012-08-13 13:06:50,159 TP-Processor9 ERROR user 786x13497x1 16q0vol 10.203.201.222 /secure/QuickCreateIssue.jspa [groovy.canned.utils.ConditionUtils] javax.script.ScriptException: java.lang.NullPointerException: Cannot invoke method getAt() on null object
2012-08-13 13:07:56,377 StreamsCompletionService::thread-1607 WARN anonymous com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor [atlassian.streams.internal.AppLinksActivityProvider] Unable to retrieve filter options from /rest/activity-stream/1.0/config?local=true
