I have a question regarding validating a Jira Checklist.
We are currently using a Add-On named Checklist which gives us the opportunity to validate / transition issues based on the input.
Now the situation:
We have 1 checklist with 3 options:
When Meets SLA Requirements is not checked, we go to the status: Waiting for customer. This is approved by the following condition:
if(issue.get("customfield_10538")?.first()?.checked == true) { false } else if(issue.get("customfield_10538")?.first()?.checked == false) { true }
But now, I want to check if the 2nd or 3rd option is checked as well so that we can transition to something else. But changing the .first to .second or .third does not work.
How can i do this?
Hi Mitch,
I guess you are using GroovyScript? You can probably access each row by using the array index.
customFieldValue = issue.get("customField_10538")
if (customFieldValue != null && customFieldValue[0].checked) {
false
It is zero-based, which means [0] is the first one and [1] the second one, and so on.
I hope this helps!
Maxime
