Checklist in Jira Issue Screen
Dirk Bromberg
June 18, 2014
I want a checklist in the jira issue screen to show the task which should be done in the last state.
Is there a good solution for this? Maybe to show a confluence page in the issue screen?
Dirk
Alina Kachan_Railsware_
Hey @Dirk Bromberg
You might also want to consider Smart Checklist add-on for creating easily manageable todo lists in your Jira issues. Btw, you can find it extremely handy if you're looking for big checklists management - Markdown syntax the app supports will get you covered.
Sebastian Brudziński
as you have noticed, there are several apps that can enhance Jira issue view with the actionable checklists. We at SolDevelo have developed a cheap, light-weight version of the checklists functionality in our recent app - Multiple Checklists for Jira
It allows adding a chosen checklist to each of your Jira issues automatically, so you don't forget about the tasks that need to be done in the last state.
An alternative is adding this manually to issues description, but as you can imagine this can be troubling and easy to miss.
Best,
Sebastian.
Gebsun
September 10, 2016
For Cloud JIRA, you can try our Checklist add-on: https://marketplace.atlassian.com/plugins/com.gebsun.plugins.jira.issuechecklist/overview
Regards, Gebsun
Jack Hunter [HeroCoders]
There is also available free version of the Checklist app: https://marketplace.atlassian.com/apps/1220209/issue-checklist-free?hosting=cloud&tab=overview
Like • Limor Hader likes this
Andrey Markelov
July 3, 2014
Timothy
June 19, 2014
I think this is a good idea. However, you can't render the Confluence page in JIRA but you can definitely link Confluence pages into JIRA issues.
