Clear defaulted values in Priorities
mel vega
I added a defaulted value in Priorities but I would like to remove this defaulted value and have no default value anymore for the priority but I can't get how to do that. For example in Resolutions Filed, I see an option "Clear defaulted values" but not for the priority....
Any ideas?
Thanks in advance
Melissa
Rocio_Mtz June 27, 2019
Create a new priority, set this one as default and then delete it. So default value will be erased.
Simple but it works!
Asia R
February 25, 2020
I tried this and the system automatically chooses the default value. Has anyone else tried this?
Deleted user March 4, 2016
The Priorities you are talking about here may be a "Custom Field" list choice on which the default values can be set in the "Issues > Custom Fields" page
