Clearing custom field value based on the selection and updating the new values
Komal Parate July 8, 2021
I have the following fields in our assign screen :
  1. Incident category
  2. Incident item.
  3. Incident summary.
  4. Technician office code
  5. select name
on one screen whenever our users select the category and item and summary from the dropdown they will have to select the technician office code and the name of the individual will be displayed in the select name field.
The issue we are facing is that whenever we try to click on the other options in incident category for eg incident category has two options crm and hrms then if user selects crm the technician list name of that category will appear and when the user selects hrms the technician list of that category should appear but however when we try to change the category from CRM to HRMS the values of select name are not changing it retains the old category value .
We have two values in technician office code "109897" and "Company" we have to toggle between theses two options eg. first click on 109897 and then click on "Company" to update the field select name with correct value .
Is there any function which can update the value of select name as soon as the category is changed.
We are using below code to set the name field
import com.atlassian.jira.issue.customfields.option.Option
import com.atlassian.jira.bc.user.search.UserSearchService
def id = getFieldById("id")
def currentIssue = ComponentAccessor.getIssueManager().getIssueObject(Long.parseLong(id.getValue() as String))
String Technician_Office_Code = currentIssue.getCustomFieldValue(ComponentAccessor.getCustomFieldManager().getCustomFieldObject("customfield_161")) as String
log.error"Technician office code"+Technician_Office_Code
if(getFieldById(getFieldChanged()) != null ){
String assigneeName = getFieldById(getFieldChanged()
def selectAssignee = getFieldById("customfield_12")
def optionsManager = ComponentAccessor.getOptionsManager()
def customField = customFieldManager.getCustomFieldObject(selectAssignee.getFieldId())
def config = customField.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
List<Option> optionsSelect = new ArrayList<Option>()
def userSearchService = ComponentAccessor.getComponent(UserSearchService)
def users = userSearchService.findUsersByFullName(assigneeName)
List<String> test = new ArrayList<String>()
for(def user : users){
// test.add(user.getUsername())
test.add(user.getName())
for(String optionStr : test){
boolean f = true
for(def option : options){
if(option.getValue().trim().equals(optionStr.trim())){
optionsSelect.add(option)
f = false
break
if(f){
optionsSelect.add(optionsManager.createOption(config, 0, 0, optionStr))
def selected = [:]
selected += optionsSelect.collectEntries{
[(it.optionId.toString()) : it.value]
//log.error"-------------xxxxxx79xxxxxxx----"+optionsSelect
selectAssignee.setFieldOptions(selected)
}else{
getFieldById("customfield_12").setHidden(true)
getFieldById("customfield_12").setRequired(false)
getFieldById("customfield_12").setFormValue(null)
getFieldById(getFieldChanged()).setFormValue(null)
July 11, 2021 edited
Hi @Komal Parate
After reviewing your code, my first question is why are you trying to invoke the issue using the:
instead of just using the underlyingIssue, which is an inbuilt variable in the Behaviour?
If your goal is to invoke the issue variable in the Behaviour during the creation of an issue, this is not the correct approach.
However, you can invoke the underlyingIssue variable in the Behaviour once the issue is created. To ensure that the variable is accessible only after the issue has been created, you can use this condition.
if(underlyingIssue) {
Also, why are you invoking the custom field using:-
You could just use:-
def customField = getFieldByName("Sample")
def customFieldValue = customField.value.toString()
or, if you want to update a field value field in the Behaviour, based on another field, you could invoke the value like:-
def list2 = getFieldByName("List2")
def customFieldManager = ComponentAccessor.customFieldManager
def optionManager = ComponentAccessor.optionsManager
def list2CustomField = customFieldManager.getCustomFieldObject(list2.fieldId)
def list2Config = list2CustomField.getRelevantConfig(issueContext)
def list2Options = optionManager.getOptions(list2Config)
Regarding your question about resetting your value, could you please share a print screen of your behaviour configuration? This is to get a better understanding of your current behaviour configuration and provide a better solution.
I am looking forward to your feedback.
Thank you and Kind Regards,
Ram
