We had a JIRA server migration with same database, after migrate clone+ and clone++ is not working. it shows 404 error when click on clone+. What is the cause for that ?
You forgot to install the JSP files required - see JSP Installation Instructions. Once you get to JIRA 6.4 or higher, you can upgrade to a release of Clone Plus for JIRA that does not need JSPs to be installed.
JIRA 6.2 . Yes everything was ok. please see the log details
org.apache.velocity.exception.VelocityException: Error getting iterator for #foreach at templates/greenhopper/jira/customfield/sprint/sprint-macros.vm[line 3, column 1]
at org.apache.velocity.runtime.directive.Foreach.getIterator(Foreach.java:435)
at org.apache.velocity.runtime.directive.Foreach.render(Foreach.java:287)
at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:175)
at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:72)
at org.apache.velocity.runtime.directive.VelocimacroProxy.render(VelocimacroProxy.java:212)
at org.apache.velocity.runtime.directive.RuntimeMacro.render(RuntimeMacro.java:247)
at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:87)
at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:336)
at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:106)
at org.apache.velocity.runtime.directive.Parse.render(Parse.java:263)
at org.apache.velocity.Template.merge(Template.java:328)
at org.apache.velocity.Template.merge(Template.java:235)
at org.apache.velocity.app.VelocityEngine.mergeTemplate(VelocityEngine.java:381)
at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBodyImpl(DefaultVelocityManager.java:117)
at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBody(DefaultVelocityManager.java:97)
at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.toWriterImpl(DefaultVelocityTemplatingEngine.java:146)
at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.asHtml(DefaultVelocityTemplatingEngine.java:134)
at com.atlassian.jira.plugin.AbstractJiraModuleDescriptor.writeHtml(AbstractJiraModuleDescriptor.java:133)
at com.atlassian.jira.plugin.AbstractJiraModuleDescriptor.getHtml(AbstractJiraModuleDescriptor.java:109)
at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl.getHtml(CustomFieldTypeModuleDescriptorImpl.java:309)
at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl.getEditHtml(CustomFieldTypeModuleDescriptorImpl.java:187)
at com.atlassian.jira.issue.fields.CustomFieldImpl.getEditHtml(CustomFieldImpl.java:1039)
at com.atlassian.jira.issue.fields.screen.AbstractFieldScreenLayoutItem.getEditHtml(AbstractFieldScreenLayoutItem.java:78)
at com.atlassian.jira.issue.fields.screen.FieldScreenRenderLayoutItemImpl.getEditHtml(FieldScreenRenderLayoutItemImpl.java:62)
at com.atlassian.jira.issue.fields.rest.FieldHtmlFactoryImpl.getEditFields(FieldHtmlFactoryImpl.java:151) <+2>
at java.lang.reflect.Method.invoke(Unknown Source)
at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:129)
at com.sun.proxy.$Proxy277.getEditFields(Unknown Source) <+2>
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at com.sun.proxy.$Proxy2085.getEditFields(Unknown Source)
at com.atlassian.jira.components.issueviewer.viewissue.IssueFieldProvider.getEditFields(IssueFieldProvider.java:32)
at com.atlassian.jira.components.issueeditor.action.AjaxIssueEditAction.doDefault(AjaxIssueEditAction.java:57) <+2>
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56) <+2> (ActionSupport.java:438) (ActionSupport.java:157)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:87) <+7> (DefaultInterceptorChain.java:39) (NestedInterceptorChain.java:31) (ChainedInterceptor.java:16) (DefaultInterceptorChain.java:35) (GenericDispatcher.java:225) (GenericDispatcher.java:154) (JiraWebworkActionDispatcher.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) <+2> (ApplicationFilterChain.java:305) (ApplicationFilterChain.java:210)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51) <+14> (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (XContentTypeOptionsNoSniffFilter.java:22) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (HeaderSanitisingFilter.java:44) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:66)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39) <+3> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38) <+8> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66) (ContextFilter.java:25) (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) <+3> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) <+3> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) <+3> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) <+3> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) <+21> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (AccessLogFilter.java:103) (AccessLogFilter.java:87) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (XsrfTokenAdditionRequestFilter.java:54) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (SitemeshPageFilter.java:119) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:66)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+22> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (SecurityFilter.java:234) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (TrustedApplicationsFilter.java:100) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (BaseLoginFilter.java:169) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:66) (OAuthFilter.java:61) (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+13> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (ProfilingFilter.java:99) (JIRAProfilingFilter.java:19) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (AbstractJohnsonFilter.java:71) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) <+10> (UrlRewriteFilter.java:394) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (GzipFilter.java:80) (GzipFilter.java:51) (JiraGzipFilter.java:55) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:66)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+41> (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:66) (JWDSendRedirectFilter.java:25) (DelegatingPluginFilter.java:74) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (AbstractCachingFilter.java:33) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (AbstractEncodingFilter.java:41) (AbstractHttpFilter.java:31) (PathMatchingEncodingFilter.java:49) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (JiraStartupChecklistFilter.java:78) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (ChainedFilterStepRunner.java:87) (JiraFirstFilter.java:57) (ApplicationFilterChain.java:243) (ApplicationFilterChain.java:210) (StandardWrapperValve.java:222) (StandardContextValve.java:123) (AuthenticatorBase.java:502) (StandardHostValve.java:171) (ErrorReportValve.java:100) (StandardEngineValve.java:118) (AccessLogValve.java:953) (CoyoteAdapter.java:408) (AbstractHttp11Processor.java:1041) (AbstractProtocol.java:603) (JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IllegalAccessException: Class org.apache.velocity.util.introspection.UberspectImpl can not access a member of class com.google.common.collect.Iterables$8 with modifiers "public"
at sun.reflect.Reflection.ensureMemberAccess(Unknown Source)
at java.lang.reflect.AccessibleObject.slowCheckMemberAccess(Unknown Source)
at java.lang.reflect.AccessibleObject.checkAccess(Unknown Source)
at org.apache.velocity.util.introspection.UberspectImpl.getIterator(UberspectImpl.java:148)
at org.apache.velocity.runtime.directive.Foreach.getIterator(Foreach.java:422)
... 241 more
2. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
2015-12-21 09:11:40,785 http-bio-80-exec-160 ERROR imerkulo 551x28906x1 vuuqxm 10.124.156.199 /secure/AjaxIssueEditAction!default.jspa [velocity] java.lang.IllegalAccessException: Class org.apache.velocity.util.introspection.UberspectImpl can not access a member of class com.google.common.collect.Iterables$8 with modifiers "public"
at com.atlassian.velocity.htmlsafe.introspection.AnnotationBoxingUberspect.getIterator(AnnotationBoxingUberspect.java:148)
at sun.reflect.GeneratedMethodAccessor622.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.GeneratedMethodAccessor1530.invoke(Unknown Source)
at webwork.action.ActionSupport.invokeCommand(ActionSupport.java:438)
at webwork.action.ActionSupport.execute(ActionSupport.java:157)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154)
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:119)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:234)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:169)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:61)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:80)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:55)
at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:78)
at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:57)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
Looks like the vm files have been changed. Can you try what I suggested above? Clear the plugin caches and reinstall/install the plugin?
