I would like the ability to clone an issue in JIRA and to specify the project the issue will be cloned into.
Edit: I am using the cloud based version of JIRA.
Look at the Clone Plus App. I have used this for several years and it works great for this.
Looks like it should work if you are running server version. I am on the cloud based instance.
Why do all 'standard' features cost extra with JIRA?
It seems like everything I want to do with this tool is only available via a paid extension. Pretty lame...
Not sure why I would stick with JIRA rather than a similarly priced competitor that doesn't nickle and dime every feature -- or rely upon the community to fix their product. /rant.
