Hi all -
I have a rather large script which does a lot of stuff and I get it to work bit by bit -
this last part is supposed to create a link to a cloned issue - which is does but in the wrong direction
I want to achieve that it creates an outwards pointing link
From the Parent to the Cloned issue
so in the PARENT ISSUE I would like to see:
"is cloned by" - to my definiton an "outward pointing link"
so I tried this
for (IssueLink link in linkManager.getOutwardLinks(issue.id)) {
and the CLONED ISSUE should have
"clones" - to my definition an "inward pointing link"
so I tried this
for (IssueLink link in linkManager.getInwardLinks(issue.id)) {
But I cannot get it to do this -
It always places a
"clones" in the PARENT ISSUE
and a
"is cloned" into the CLONED ISSUE
[ START OF SCRIPT SNIPPET ]
def sequence = 0
if ("Cloners" == link.issueLinkType.name)
sequence++;
Collection<IssueLinkType> issueLinkTypes = linkTypeManager.getIssueLinkTypes()
String linkID=null;
for (IssueLinkType issueLinkType : issueLinkTypes)
String name=issueLinkType.getName();
if(name.equals("Cloners"))
linkID=issueLinkType.getId();
break;
Long issueID = new Long(issue.id).longValue();
Long newissueID = new Long(newissue.id).longValue();
Long TheLinkID = new Long(linkID).longValue();
Long TheSequence = new Long(sequence).longValue();
linkManager.createIssueLink (issueID, newissueID,TheLinkID, TheSequence, currentUser)
[ END OF SCRIPT SNIPPET ]
Any hint be very much appreciated
thanks a lot
Werner
Hi
have you tried reversing the issue ids in call
linkManager.createIssueLink (newissueID, issueID, TheLinkID, TheSequence, currentUser)
Hi Tom - your suggestion indeed turned it upside down - the right way - thanks a lot
- I did not think it would make a difference, but never tried - I should have tried.
Thanks again.
Great news
could you mark as answered for others to find
Hi Tom, I thought I did press the answer button - but it did not work - I have to use a different browser to get this functionality. It is the same for the REPLY button - it does not show in Internet Explorer - only in Firefox.
cheers
